brian015
brian015's Avatar
06.25.2010, 06:47 AM
Originally Posted by transtalon View Post
You should weld the ends with a stainless steel hollow tubing. I had one with a brazed weld and it broke off. I had one tig welded and I never had problem with it. You can also mig weld it if you want. I don't think the aluminum tubing will hold up, i think it will twist or your setscrew won't hold up under big tires and lots of power. I could be wrong though. Goodluck.
If I could weld steel, I'm sure I would have gone this route. As it is, I'm trying to do this project without paying for custom parts, so I'm using materials and processes available to me. If this Al tubing twists, I'll probably have to get something custom made - so thanks for the advice.
Here is a picture of the cross section of the tubing, just so people aren't imagining some thin-walled Al tube:
