02.21.2006, 07:53 AM
No pics - But i can describe how I did id Johnymaxima - In the back of the charger where you make your positive and negative connections - i used the largest wire i could - made it about an inch and a half - on both sides - and then soldered 3 smaller guage wires to the positive wire and 3 smaller gauge wires to the negative wire - which i soldered my deans connectors to. Then on each charger - for the power leads i soldered deans connectors onto each of the chargers and plug them in as needed - I can have one two or three plugged in at a time. Really quite simple - not the prettiest if you were to look at the back of the power supply - but function beats form for me in this matter.
Hows that "Hope and Change" working out for Ya???
