Had to shim the slipper plate side away from the motor mount by .25mm (1 shim) and its fine, the slipperential is about 1mm longer than the losi diff so there was a tiny bit of strain on the front mount, it doesnt make it bind or anything, so it should be fine. Spring for the hardened steel front plate losi guys! for the extreme front driveshaft angle, the steel plate will wear less than the aluminum plate.
Had some difficulties getting the slipper pads in, I had to dremel 2 of the 3 to sit correctly in the spur gear. No big deal. Works great and softens the initial hit of my sensorless MMM system. Paired with a brand new Rc-monster Pinion, this sucker is quiet!! It only is slightly loud under braking, Probably because the gears need to be broken in.. Race testing Tommorow!
Bottom Line:
Amazing product
Near perfect fit and finish
9.5/10
