jhautz
jhautz's Avatar
06.26.2010, 12:07 PM
Sorry for the bad news but if your budget will only allow a couple hundred dollars to be spent, forget about it. The MMM ESC is not ideal to handle the excessive weight of the much larger RC. SO..... you'll need another Motor, (Much larger and lower KV) and a ESC. Even 6s is not enough to run the more powerful motor required efficently.
Your Firehammer may "seem" only a little heavier, but 5-6lbs is a really big deal.
+1
Electric 1/5 is not a "budget" project. You can probably find something that will make it run for your budget, but I guarantee you wont be happy with it in the end. Your just asking for headaches IMO.
to make it...
or break it...
Silent...But Deadly
