Originally Posted by Rusty4Ever
Ability to gear the 540 can's higher tho doesn't apply to directly in my case right because I'm not into topspeeds? So for my quick bursts to my ramp either would probably do, but I'm suspecting the 380C (L) would do it at lower amps overall (I'm hoping).
I was saying that a lower kv 540 motor(like a 4200) geared to the same speed as a faster turning 380(like a 4900)on the same voltage doesn't need to spool up as fast to give the same acceleration.Higher gearing ratio yes but not geared to a higher speed,if you see what i mean.:032:
I agree,i think either would work for you,i'd probably try a 380c considering the price.
