Topsy Kretts
Topsy Kretts's Avatar
06.29.2010, 11:21 AM
Thanks Yeah I'll check it out, I waited a while before I bought Mike's conversion to see if the 4x4 class would keep up with the 2wd class. Well it seem to be catching up with 2wd I Love this conversion I used a 1509 1.5y/f Neu motor geared at 54/17 with a MMP esc with 0 punch control to start, HOLY CR&P Batman this thing is the bomb The nitro set-up has nothing on this!!!!!! Temps were just warm to the touch,not worth putting a gun to, that is using 4200mah 4s packs. Diffs are 5/7/3 but may go to 5 in the center to get a bit more steering,really have not played with the shocks yet.This puppy has a ton of potential,and its built as heavy duty as any 1/8 scale out there If you are on the fence about this conversion kit,time to climb off Best money I have spent on RC in a while!!! Thanks Mike and all you Guy's that help point us in the right Direction.
