Thread: SC18 hot motor
simplechamp
simplechamp's Avatar
06.29.2010, 02:06 PM
It's possible that the belts are loosening/stretching a bit as you run, and easing the tension on the drivetrain, allowing it to run cooler as time goes on. I've heard other people report this.
I'll have to see when mine gets here, picked it up used for $80, only 3 packs run through it. Hopefully can get a few bucks out of the 2.4GHz system and stock elecs to put towards a BL system. I told myself I'd never get another mini, but when this came out I knew I'd get one. Should be much more capable than my Mini-T though, that left a bad taste in my mouth for mini's.
