02.21.2006, 03:06 PM
Hi Shaun!
listen, it won't be possible to get the batteries inside the tvp's when you use the stock transmission, even with the truckzilla tvp's there is not enough room for 18 cells.
I would use the trays you have and put them outside the TVP's.
You have got a motorplate?
with the 9918, you are able to use 20 cells, (the 9918 is relabeled to 9920, without ANY technical changes) and that 9XL can take the 20 cells as well.
trust me, it will be a blast! what drivetrain hopups did you use? i suggest taking the FLM bulkless or GPM diffhousings. a set of the HB8019 diffcups (hotbodies) won't hurt either. with the power of that setup, it's likely you will snap a dogbone (if these are the stockers)
