Jahay
06.30.2010, 04:58 AM
Originally Posted by nuz69 View Post
For jahay :
9 x 4,2V = 37,8V ^^ (when fully charged)
37,8 x 1600 = 60480 RPM !! I think you hit the RPM limits
In 8S : 53760 RPM.
That is true nuz but i calculate it using 3.7v as if the motor was under load. So then the result is 9x3.7= 53,280 which is well within the limit.
I have heard that a few people on here have pushed 10s quite comfortably.
So i thought 9s would be more than fine. Plus i wont be running 9s most of the time, mostly 6s or 7s. 9s will be for speed runs.
Wouldnt this be ok? i want to get the most from the motor... They are built well and should be able to handle it right? Or would i be better going 8s?
