brian015
brian015's Avatar
07.01.2010, 12:08 PM
Ok, so I want to try to tune this thing a little to reduce the oversteer by changing the diff oil weights. Right now I'm running 10k/100k/10k. Do you think I should try reducing the oil weight in the center or the rear diff first? From what I read, either should reduce oversteer. Any thoughts are appreciated - thanks.
