Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.02.2010, 01:18 PM
Yeah, Doesn't make much sense that you have glue everywhere ?
The Tires; I'd maybe try reheating them till the CA gets soft then wipe them down with acetone on a rag while it's soft OR dremel sanding drum and a cut-off wheels to get in the places the drum can't reach. Yes you'll grind a little rubber but not a big if it's only a small amount.
The Rims: The CA should flake right off, try a small flat blade screw driver and chip it off.
