Originally Posted by nuz69
You definitly should try the punch control. Try it just for a few pack at 60-70%, maybe it will be OK for you, and it definitly would increase your pinions life ;)
Before changing the spur, try NOVAK pinion, with plastic spur you will break the spur every set of lipo :(
the hpi spur gear for the savage is very wide and durable. i was having problems with pinions wearing fast and i switched over to the plastic spur and haven't had any problems, even with the countless standing backflips and 0% punch control.
trust me, unless your mesh is bad, a plastic spur will hold up just fine.
