danielc79
07.05.2010, 11:05 PM
my 5t conversion also has been having problems. went through 2 standard drive gears till i switched to a HD drive gear, that problem fixed. I broke an axle also, but up where the dogbone goes into the axle, one whole side broke off.
i'm having steering problems also, i have standard diffs and have heard putting some heavy diff fluid in will help with steering. Nothing stripped out in the diffs but may go to bulletproof next just in case. i did find both of my bottom arm pins on the front were bent, as well as the aluminum arm brace was screwd up so that may be doing it also.
just seems alot of problems come up when all that weight gets added on.
