07.06.2010, 09:16 AM
Well, since ( generally speaking ) spurs are twice the size of pinions/ twice the number of teeth, for every revolution the spur makes the pinion makes two, so the pinion's teeth will wear down twice as quickly. This assumes the pinion and spur are well meshed and of the same material, but even with a plastic spur and metal pinion, the pinion will wear faster..
