Overdriven
Destroyer of Tires
Overdriven's Avatar
07.07.2010, 08:07 PM
overdriven, could you please explain a little furthur about the belt driven touring cars and how their performance differs to shaft vehicles
Originally Posted by V0RT3X View Post
As the shaft spins it creates force(centrifugal?) to one side of the vehicle and it slides. Atleast that's what I read on drift forums.
To my understanding it's not centrifugal force that causes shaft driven cars to drift or wander. It has more to do with the torque being transmited through the shafts under acceleration and how it acts on the chassis. The effect is more gyroscopic than anything.
Either way, it's created by the motor trying to accelerate the car through the drivetrain. If you've ever powered up an electric motor while not attached to anything and watched the whole thing spin around, that's kind of what's happening here. Now picture that force in a typical shaft vehicle and you can see that force wants to push the vehicle to the side.
During acceleration, a powerful motor may already have the tires on the edge of traction. This makes it easier for this gyroscopic effect to Break traction and push the car to the side. Touring cars have a relatively small tire contact patch for their size and weight. They are also sensitive as far as handling goes, so brushless motors almost forced these cars to belt drive. Brian's creation weighs alot but is just so powerful and on grass so he's seeing the effect also. I've seen it on my 1520 powered erevo on 6s as well.
I'm not sure if belt drive creates any gyroscopic effect of it's own. But the layout of the motor shaft and pulley shafts means any forces would be directed to the front or rear not to the sides.
