brian015
brian015's Avatar
07.07.2010, 10:08 PM
I read the entire thr3ead and didn't find the answer.
Hey brian015- you are running 23mm hexes in a 24mm hex wheel. Did you do anything about the size difference or are you just letting her buck? I want to run those wheels/tires on my LST. Thanks! -Harold
Yes - 23mm hexes in 24mm wheel hex.
Don't make me admit what I'm doing!
I'm using a very high-tech solution called folded over aluminum foil wrapped around the hexes to fill up the space. It's worked fine. When it has fallen out, they run without a problem, too - I didn't see any damage to the wheel hexes. If I get around to buying some aluminum tape, I'll use that and it will probably stay in better.
-brian
