07.08.2010, 07:08 AM
Originally Posted by respirologyrc View Post
what pinion should i be running for this setup? i have a 2200kv monster mamba motor and esc. I am using a 48t spur, front and rear diffs are essentially the same as buggy diffs.
We need to know what tires you will be running to suggest a pinion. They are buggy diffs! UE just renamed ofna diffs and called them "Super 6 and Super 8"
30k in the middle?? I was going to try a more traditional 7k front, 10k middle, 3k rear. What makes you say 30k center? just curious. I've been racing for 5 years and am pretty decent at the clubman level.
I have a heavy e-maxx with a CD and less than 30k unloaded quite a bit to the front. Turning the CD so the motor faced forward helped that and made jumping much more manageable. I guess whatever truggies are using in the CD should work. I have never raced.....
