Originally Posted by Superemaxx89
In a nutshell, to power your sytem you should buy one motor (probably like a 12-14xl...why do you want to run two motors anyway?), one esc, save money (by only buying one system) and then buy--i know this may sound crazy-- two 10s packs and wire them parallel.
Superemaxx89-
I've been running dual 9L's for a while now. I run the dual's mainly just because I can. My truck is more of a "show truck" and only gets run in the street and occasionaly on the grass. I have another single BL Maxx that I use for bashing.
The dual's are run seperate of eachother, each with their own speed control and own set of batteries. So correct me if I'm wrong (which is highly probable as I am still new to this r/c stuff) if I am running my setup as described above, the 2 LiPo packs (one 5s per motor and speed controler) have nothing to do with eachother? Forgive me if this is not what you were talking about, because 99% of what you said was way beyond me.:002: :005:
I do however like your idea for a setup (12-14XL on two 10s packs) for my single BL Maxx!
