07.14.2010, 04:10 PM
I took the wires out from the balance board. I don't feel like buying just the wiring harness either. So I took them out and soldered on the pins, which I just plug into my balancing ports on my batteries. Easy enough for me and I don't need adapters and whatnot...
I do something similar, except the end of the balance wires terminate in a pin header (pic and pic). This allows me to use any balance plug with the standard 0.1" spacing. The only exception is some older MA packs I had which use the Hyperion pinout; for these, I just resorted the wires.
