Originally Posted by blueb8llz
im going to try and explain this the best i can.
i already have the shocks set to the inner shock tower and and widest on a arms. i have no preload spacers on my springs.
when i compress the truck, the arms are completely level . but when i lift up the truck from the bottom chassis. the springs/shocks will decompress and raise the truck.
thats the part i want to fix.
on my emaxx i have it to the lowest setting as well, but when i lift up the truck from the chassis, the springs/shocks will decompress and just raise 1-2 centimeters while the lst will raise like a inch or maybe even more.
i want to make the lst like how the emaxx is. anybody know of a fix??? maybe some different shock towers that are a direct bolt on?
thanks everybody
The easiest way to lower your LST, is to put some limiters inside the shocks. This is easy to do, depeding how much you want to lower your truck. Just take some fuel tubing & cut it to the appropriate length or you can get some 1/8 in o-rings & put them on your shock shafts. This is how we lowererd are Stadium trucks & monster trucks for racing on-road on Carpet & asphalt.
