nuz69
nuz69's Avatar
07.21.2010, 06:20 AM
When the grip is good, the acceleration and the amp draw is higher (dust vs on road for example)...
So it does not necessary tape the current spikes, but power the motor to get the best grip conditions. More power is given to the ground than temp and amp should not necessary be lower than before.
I am still concerned about the punch control disabled when the torque control is activated, so there is still amp spikes during a kickdown. That's why IMO you can't for the moment use lower C rating batteries... The next version will probably fix this anyway.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
