07.26.2010, 12:32 PM
Originally Posted by Freezebyte View Post
Whoops, need to add that you will not find a "powerful" charger that has a built in PS.
That charger you link will only do 100 watts, so 4 amps at 6s. Not powerful IMO. 2c charge rates are a must, as the minimum, so a 10amp capable charger is a min, at 6s. So that would have to be 260 watts.
Cheap chargers suck, get something decent dude. Or don't listen and get a triton and some smc lipos...
You can run the 30-40c HC lipos, I see no probs with them in general. Go to a pair of 3s packs, run them as 6s and gear down to a 15-17t pinion on that flux.
