I recieved my two USB plugs today in the mail, hip hip hurray, hip hip hurray :) -
07.26.2010, 09:47 PM
Now I can plug my two 30amp chargers into my laptop computer and control every aspect of charging my batteries. But I believe I have to first load some software into my computer to make it communicate with both the USB and the chargers. I know nothing about computers so I'll keep everyone posted on my progress. Howard in Tech Support and I are working closely together on getting me started with my new FMA Direct, CellPro, PowerLab 8, Chargers. Was that one word, wow. I have been looking at the owners manual online, but now that I can plug the chargers into the computer, I think this will make it much simpler and easier to set up the chargers. I will keep this thread updated on all progress. I do know one thing for sure, as soon as I mention ten minute or less lipo charging, everyone at my track ask me to write the name of the charger down because they want one as well. I mention the slightly less battery life as a result of the high powered fast charging and so far, not one person loses interest in the fast charging capability. My thoughts exactly. Thank you FMA Direct and CellPro for making a 30amp charger that can also balance at up to 1amp, rather than 300-350mah(the balancing parameters of most lipo balance chargers on the market today, that I know of) that's a big diference in balancing speed as well.
PS. please keep in mind that not all lipo batteries can take a 30amp fast charge. Be sure to confirm this with your battery manufacturer before charging any LiPo battery above and beyond 1c. If a battery is 5000mah, then one c charging is 5amps. If you charge at 5c, then five times five is 25amps. I run the Thunder Power 5200mah 50c(relates to constant amps available, not charging amps). It's always best to buy a charger with a built in balancer, and always balance charge your lipo batteries no matter what the amps rate of charge. This is the best way to assure a longer life of your batteries, and prevents the overcharging of any one cell, which can lead to battery failure. It's also best to charge batteries in a lipo sak, or lipo charging bag, they are fire proof and I'm in the market to buy one right now. If anyone knows of a good, nice and or low cost lipo charging bag, please let me know. Thank you in advance and thank you to everyone keeping this thread informative and educational. These chargers are truly awesome in every way.
