MetalMan
MetalMan's Avatar
02.22.2006, 10:17 PM
Originally Posted by 4u2nv
NO!! If you look at the auction, it says this pack has 18ga. wire... That's WAY too thin. Even if the wire was thicker, I would not trust these "new Chinese cells"... Go for something with a reputation, like Hyperion, Polyquest, or LiMn.
20C is unnecessary IMO. If you get a pack that can handle about 45amps continuous with 80amps burst then that should be adequate. A 6000mah 8C pack is rated to deliver 48amps continuously (for example), and would give better runtime than a 4000mah pack. Unless you are extremely worried about weight, I wouldn't even get a 20C pack. You pay a lot extra for them, and 10C-15C packs are plenty...
