Thread: My New Build
redshift
RC-Monster Square Tube
redshift's Avatar
07.31.2010, 03:32 PM
On to the chassis...
Square tube is the simplest and strongest backbone, and after finding my dimensions I welded some chunks of aluminum onto the tubes. Four on each end, that would have gaps subsequently milled out, then end-drilled. The welds were then rough-cleaned-up using both inner and outer radius mills, and the setscrew pin retainers drilled and tapped. Next up was the joiner plate holes, the joiner plates themselves, and the provisions for the motor mount and aft bearing block were then done. As you'll imagine, this was a ton of work... and I still have finish work, mostly on the A-arm pivots.
Name:	Chassis Rear 003.jpg
ID:	9192   Click image for larger version
Name:	Joiner Plates.jpg
ID:	9193   Click image for larger version
