brian015
brian015's Avatar
08.03.2010, 07:02 AM
Just read the entire thread, very interesting and I like it!!!
Thank you.
As far as the spindles go, buy the al ones from New Era, best made for the lst2. I have them on mine and have no issues, run rpm arms and the stock lst2 rear hubs and stock lst2 c hubs. Stock hige pins as well.
Good - I'll keep the New Era spindles in mind if the RDLogics don't work out.
Your idea to run long bolts thru the chassis/bulks and to a new top plate is a good one. Will give the shock tower something better to mount to as well.
I think it's a good idea, too - I just have to get around to doing it!
I am now rethinking the body, your exposed cage looks great, and I have made alot of tube bodies and chassis (I weld).
I've been looking at some of the sand rail conversions they're doing on the Baja's and really like the look of some of them - if only I could weld.
Baja Sandrail conversions
Look forward to seeing who your 10s setup works out.
Yeah, I'm pretty convinced that 10s is the way to go with my 1527 1.5y (that gives it 30500 rpm). I want to squeeze in an extra 2s 5000mah 40c pack to run 10s with those packs (I'll have to stack a battery). To give me more battery options, I wish my chassis were about 1/2 inch wider. Oh well, I'll make it work.
