danielc79
08.03.2010, 09:50 AM
i'm a basher and have the 5t conversion from tcs on mine. i used 30/30k at a suggestion of a fellow member and it seems to be doing fine. it seems to be harder to turn, but i'm also still using stock servo, so maybe its just weak with so much weight (7.5inch tires from cen nemesis too)
back to original thread question though, my first upgrade would be the radio if you don' thave 2.4 ghz, then probably the tvps. i still have the stock non bulletproof dif's in mine and even with the weight of the conversion and huge tires they are holding up just fine. when i filled my diffs about a month ago they aren't even showing signs of use.
i have broken 3 stock A arms 2 tops 1 bottom both on front, but that was some serious abuse. i'm not sure rpm could have held up to what i did, the stock arms seem very strong. but rpm a arms wouldn't be a bad investment, they are guaranteed for life after all.
