02.23.2006, 09:34 PM
A 6s 6000mah 15C pack would be quite expensive! I myself can hardly afford a 4s 5400mah 8C pack... In this case it does come down to the budget, and desired weight.
A 6s 4000mah 15C pack could dish out 60amps continuously, for an average continuous power output of about 1200watts (depending on the particular cells), and should be capable of 10sec. 20C bursts, which gives about 1500watts burst. More could be attained in peak draws, I'm guessing about 1800watts. Even this pack would be rather expensive, I'd estimate $300-$315... That's a lot! About 3 times more than I could spend.
