08.06.2010, 09:02 PM
The bif 1/5 scale leopard looks very interesting. Seems like a much cheaper alternative to a 2215, slightly longer and probably has a very similar diameter rotor given the case dimensions and lack of fins. Could not find a spec on a smooth can new 22 series motor, but the leopard 5692 is longer than a 2215 and shorter than a 2230. If it can push 2500 watts cont it would be a good motor for a baja conversion...Wonder if a MMM could handle it? Maybe go with the lowest kv model, mech brakes, and the new castle omgwtfbbq esc on 12s...
Or 10s and have the esc brakes for rear and some hub mounted mech brakes for the front. With a mixing capable radio you could tune the bias easily, and have presets for different surfaces. Very Nice, I like!!!
