Drivinfast247
08.09.2010, 02:30 PM
Pretty cool video, I like the ones where you bash in the woods better tho.
I think your ball popped out because you didn't install the metal rings from the stock carriers. See pic
Are you sure? I was looking at them and it only comes with 2 per set. I read the description and it say those metal rings are bearing spacers/adapters. You use them if you have the older, smaller diameter bearings. Correct?
