Thread: MMM fault
08.10.2010, 08:54 AM
Possible bad connection somewhere- check the battery and motor leads/ connectors for a broken joint. Could be something internal thats damaged though- does the motor chime like it used to before the issue started, or do you just get lights/ dodgey chime?
Do you have an padding under the esc/ how is it held down?
