08.10.2010, 10:41 PM
The motor connections are female bullets soldered to the pcb, doubt they've come loose but its easy to check- more likely something internally.
Check the esc settings on the castlelink in case the settings have been affected- sometimes they can randomly reset upon a heavy impact.
Best way to secure the esc to the chassis is with some double-sided sticky foam & the ziptie or traxxas hold-down mount, helps absorb a bit of the impact better.
