nuz69
nuz69's Avatar
08.11.2010, 11:03 AM
Shorted widings increases the motor drag brake and noise too, when you push the truck on the ground. Check the bearings first, if the strange noise is still here you will probably have to re-use the Castle support for your motor.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
