mwe-maxxowner
mwe-maxxowner's Avatar
08.11.2010, 09:23 PM
So, arct1k, is that an entire spool assembly at rcbros? I took it apart today to see how it was designed, and I can see how easy it would be for the plasic part the axleshafts slide into to strip. It would be nice to just get an entire spool as an assembly with the correct upgraded parts I can just drop right into the diff. case. Superglued it again for now.
FYI, e-revonut, I was able to get a servo saver I had lying around for my stampede to work for the broken servo horn. Works just as it should! So that is fixed.
Don't they make some wheelweights for these things?
Brushless-taking back rc!
E-revo is DONE!
  Send a message via AIM to mwe-maxxowner
