Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.13.2010, 04:44 PM
Originally Posted by Drivinfast247 View Post
In this post of yours you show a red circle around a metal ring and drew an arrow pointing to the location of the pivot ball cup. The metal ring that you circled is not for that. THAT IS THE BEARING SPACER. The rings you are talking about, come on Traxxas part #5334r, they cannot be bought separate. I am not sure if they can be removed from the Traxxas part and used on the RPM part.
I used a members pic and added in what I am talking about.
I REPEAT; TRAXXAS #5334r COMES WITH THE METAL RINGS THAT SHOULD STOP THE BALLS FROM POPPING OUT. I AM NOT SURE THEY CAN BE REMOVED AND USED ON THE RPM AXLE CARRIER.
Gee, thanks for repeating yourself ??
And yes they come off and swap over to the RPM carrier, a tricky install but nessasary.
