fastbaja5b
fastbaja5b's Avatar
08.16.2010, 05:13 AM
Green Loctite is a Bearing Retainer Compound, Mainly used to secure a pinion to a shaft without a grub screw.
Purple Loctite is sometimes called Screwlock , weakest one.
Blue Loctite is called Nut Lock, Blue and the best one to use for RC's
Red Loctite is called Stud Lock, it's Red and near impossible to undo once it's cured.
Say Less, Do More.
