Bmr4life
08.17.2010, 08:11 AM
Originally Posted by thzero View Post
Integy Rear Hubs... they seem decent enough. However, fit and finish wasn't greatest. I had to grind down the ball in the upper tie rod end to get it to fit. Also it was a damn tight fit with the bearings!! Should have taken a dremel and ground them out carefully, but I was in a bit of a rush so I suspect the bearings just won't come out!
Other thing is there aren't any instructions so you really aren't 100% sure what degrees of camber the three optional mounting points are. Will need to get out camber gauage and measure. I did use the #2 mounting point(#1 go #2, #2, go #1... ) for what I believe is 2 degrees of camber.
Put together with the XL axles and the 24mm HPI hub adapters.
Are those the HPI 86249 wide axles?
