Steering has been conquered :) -
08.17.2010, 08:19 PM
The direct servo thing was a neat little experiment, but alas, it was not to be. So I was not going to screw around this time...
Once I had some dimensions I made some bellcranks and lower bellcrank brackets. I couldn't decide on a bellcrank shaft setup I was happy with, so I decided to not use shafts. 4mm stainless cap screws were turned down to 6mm and shortened, and there are .020"/.5mm fiber washers to keep the bearings riding on the center race.
