From what i can tell. -
08.17.2010, 08:19 PM
From what I can tell your setup looks pretty good. Going over the 100 mph mark is not an easy achievement for sure. Some times it takes several passes and some tweeking to get the vehicle just right for the task. Your vehicle looks like a good setup for reaching your goal though. Running an open wheel vehicle that fast is tough. Your vehicle looks a bit lite and might want to float and lift off the ground on you. If you get close to 100 it should show you allot about the arodynamics of your setup. A front wing or some kind or defuser may be needed to keep it on the ground. You may also need to add a little bit of weight, but that is what testing is all about. Cool project. We all have our dreams. Good luck with your quest and keep us posted. Your right that RCM is the place for electric 1/8 scale. Welcome and have fun. Be careful there are some monsters lerking in here, but most are quite good in this hobby and very quick witted for sure.
