Correction
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Correction - 08.18.2010, 04:16 AM
Freeze, silicone does not expand with heat, neither does standard oil. The less air the better, just an FYI.
CORRECTION. standard oil does expand with heat. I worked onboard ships for many years and supervised transfering gasoline, diesel fuel, jet fuel, and lude oil from one ship to another and I can assure you that petrolium products do expand as the temperature rises. If you put any oil product into a container and change the temp of that substance the level will change accordingly. Hotter will make the level rise, colder will make the level drop. I remember how surprized I was when seeing just how much the levels of tanks would vary in changing temps. Maybe you were thinking about how you cannot compress oil. It is not compressable.
SUPERMAXX YOUR LIFE.
