rcjmaxx
02.24.2006, 05:02 PM
If the figure you get is under the 42000 you should be good. Depends on the kv rating and cells.
What kind of setup you going to run or is it top secert?
Truck is a TXT-1 thats 13.5 lbs with a Feigao 12XL and 8 lipo cells,currently using 54t spur and 14t pinion.No bashing,topspeed running only.
