That's All Folks!
08.19.2010, 03:08 PM
It takes quite a long time to get to the programming mode, longer than the 10 secs. that the manual says, IIRC. Make sure your endpoint/brake is at 100 or 125 percent. Will it calibrate to the radio? I think you will need to do this before you can get into programming mode.
