Thread: My New Build
redshift
RC-Monster Square Tube
redshift's Avatar
08.19.2010, 10:08 PM
The draglink is necessary. If you'll refer to post #15, my original setup was with the servo savers instead of the standard horns. I was hoping to simplify things by using independent left/right servo savers. But as I mentioned in that same post I was still using my old dished 3/4" offset rims. The added leverage imposed on the knuckles was enough to pull both front wheels inward (extreme toe-in) on throttle, and outward on braking. Given stiffer direct-mount style servo savers it would work, and it may have worked much better with the zero offset rims. I decided to try solid horns before I made the new wheels, so that combo never got tried. Occasionally I do try to reinvent the wheel, and occasionally it works :) but not this time. Some laws of nature you don't mess with...
The draglink was added purely to keep the front wheels parallel, but as an added bonus I do have the option of running one or both servos. It did require some subtrim to get the servos symmetrical, same as I had to do without the draglink. And having two savers linked should firm up response quite a bit. Steering is plenty fast even on 5V, I plan to run a Hyperion BEC on 6V soon. Running 6S I'd prefer to disable the MMM's BEC. I am much happier with the new steering, I haven't run it yet but I have no doubt this will be the ideal setup for the long term. Just have to look into the servo that got damaged, it's a bit notchy now and I hope it only needs a gearset. I know the 5645s ain't much compared to the tierod snappers most of you run, but having 2 makes that pretty much a non issue.
Anodizing probably won't happen, you have to keep in mind the finish isn't that great on the majority of the surfaces, paint hides all ;)
Thanks for the comments 'crash
