respirologyrc
08.20.2010, 01:12 AM
Here you can see that the plate allows for the dog bones to sit perfectly with no rubbing of the upper chassis deck. They sit perfectly in the middle of the outdrives. I have a piece of fuel tubing in there so that they don't bounce around too much while racing. I am using UE 57 for the front and mono bone for the rear... this chassis does not need a mono because it is the same length as a Thunder-Mono!!
Just another pic but a slightly different angle
The bottom of the chassis was machined so that i can easily remove the CDM without having to take apart the entire top plate. If you were to do this mod; all you have to do is remove the four screws and the entire CDM seperates from the Center Diff Plate (CDP).
