08.20.2010, 12:14 PM
Glad that you are being taken care of and hope that you don't get the same issue with the new MMP. If you do I suggest you re examine everything at the first sign of cogging as suspect that it is not the ESC.
It may be worthwhile trying to run it without the sensor cable in case the hall sensores were providing a bad signal to the ESC.
