Originally Posted by JERRY2KONE
You should be able to find a small vent plug for it somewhere. You may have to drill and tap it out to size, but there are vents out there for just this purpose. They are usually used on industrial type bear boxes, and come in all sizes.
Not sure what you are referring to here Jerry??? The hole is about a 1" square hole in the bottom of the diff case. The plastic skidplate "covers" it, but due to the flexible nature of plastic, it doesn't seal it very well.
