Originally Posted by mistercrash
For the middle shafts, sadly the LST middle shafts are a bit too short.
But this could be dealt with by having a slightly longer shaft coming out of the tranny. If there was a way to make a CVD shaft fit on a middle shaft hub, it would solve the problem since that CVD looks to have the right length.
This is for the rear middle shaft, for the front, I still don't know, something custom would have to be made I suppose.
This is it, just something I did this afternoon 'cause I was bored.
For the center drive shafts I use the KD center dog bone kit ( I know how much you like his Revo chassis), with Moster Mikes 8 mm drive cups on my lst diffs. I had to mod the rear center dog bones a tad, and the front drive shaft fits perfect... they have worked flawlessly for almost 2 months....
