Originally Posted by captain harlock
Does the 3695 have a 42000 rpm limit like the 36120? will the first handle a 1950/10 at 24volts using 34/51 pinion and spur in a heavy truck?
Setting the mesh is tricky if your using a motor plate,anything over about a 27T mod1 makes it difficult to reach the screws,so you'll have to snug them up,then take the pinion off to tighten them.I realised this recently,i'm going to make a sleeve instead to mount the motor.
