Originally Posted by Bondonutz
Once you get a temp gun, (should have ben bought long ago) I think you'll see your probably worrying for nothing.
Raising the punch control will help with temps as well, make sure your motor timing is set at Low or Normal at the most.
Punch is at 10% right now, timing is set to default
