Originally Posted by Bondonutz
As awesome as the RPM arms are I think they and CVD's don't mix, the arms have a ton of Flex.
Example: I run a asphault Slash oval class with Latemodel bodys and foam tires, I had to ditch the RPM arms because I was eating up tires due to the high traction flex. Went back to stockers and tire prob was solved.
Don't be surprised after your first real crash the axle looks like bananna, hope I'm wrong ?
i had them on my 2wd slash and my rustle with cvd's without any problems, we will see if i do crash it up bad and bend a cvd i will be happy to tell you guys you were right
